The internal resistance of battery and dc generator - help, I'm stuck.
Discussion in 'Homework Help' started by Christine Grech, May 31, 2015.
  1. Christine Grech
    May 31, 2015
    6
    I need to solve this, but I need help...
    'A battery having an emf of 105V and an internal resistance of 1 Ohm is connected in parallel with a d.c generator of emf 110V and internal resistance of 0.5 Ohm to supply a load having a resistance of 8 Ohms. Calculate: a) the currents in the battery, the generator and the load; b) the potential difference across the load.'
    For question number a), is it right if I use 'V=Emf-Ir' please?
  2. LDC3
    Apr 27, 2013
    920
    160
    A good place to start is to draw a diagram with the 2 voltage sources and the 3 resistances.
  3. shteii01
    Feb 19, 2010
    3,516
    515
    ^ what he said.
  4. Christine Grech
    May 31, 2015
    6
    I did draw it. Can you please tell me if V = Emf - Ir is the right equation to use for question number a)? Thank you.
  5. LDC3
    Apr 27, 2013
    920
    160
    If both positive terminals of the voltage sources are connected together, than that equation only tells you the voltage across the battery, not the voltage across the load.
  6. Christine Grech
    May 31, 2015
    6
    Ok so it is wrong, thank you.
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    As asked, post your schematic here, so we can have a look you made a correct one.
    You can do this using the "Upload a File" button below the reply box.
    Bertus
  8. shteii01
    Feb 19, 2010
    3,516
    515
    Part a asks you to find 3 things. To find 3 things, you need 3 equations.
  9. ericgibbs
    Jan 29, 2010
    2,602
    396
    Hi CG,
    Is this your diagram.?
    EMF is the open circuit voltage, so the V will be EMF - Iamp
    But more maths are required to solve the problem.
    E
  10. Lestraveled
    May 19, 2014
    1,957
    1,218
    Sounds like a job for Kirchoff's laws.
  11. shteii01
    Feb 19, 2010
    3,516
    515
    yep
  12. Christine Grech
    May 31, 2015
    6
    Oh, ok so I have to use Kirchoff's law. Thank you all. Also, thank you ericgibbs, for your diagram as I had drawn it in a different way, and did not realise what equation to use.
  13. shteii01
    Feb 19, 2010
    3,516
    515
    How do you know that their's is right?
  14. ericgibbs
    Jan 29, 2010
    2,602
    396
    Who is theirs.???
    Mine or the OP's.
    My drawing was created from the very clear description posted by the OP.
  15. shteii01
    Feb 19, 2010
    3,516
    515
    OP did not post any drawing or schematic.
  16. ericgibbs
    Jan 29, 2010
    2,602
    396
  17. Christine Grech
    May 31, 2015
    6
  18. ericgibbs
    Jan 29, 2010
    2,602
    396
    In the Top menu bar of this page , is an option named Text books, click and find the topic that you need help with.
    E
  19. JoeJester
    Apr 26, 2005
    3,403
    1,227
    I found it easier to use the Norton equivalent of the two sources and then find the equivalent resistance of the internals and the load.
  20. Christine Grech
    May 31, 2015
    6
    Thank you.
