The input given to Piezo Speaker is an analogue signal or Digital signal?
Foong Lik Wei
Joined Feb 16, 2015
Hello, I want to ask the input given to this Piezo speaker is an analogue signal or digital signal? This is because I am using digital output pin of Arduino Uno board to connect this speaker, is that okay?
Besides, if this speaker require an input analogue signal, then should I use Digital to Analogue Converter where convert the digital output pin of Arduino into analogue signal first and then feed to speaker?
The diagram of the connection between Arduino and speaker is shown in this attachment.
Reloadron
Joined Jan 15, 2015
7,523
All depends on the piezo you have. Some have a built in oscillator to drive the element and some don't. If you just have the element then you need a driver.You show a driver so it should work fine as drawn. hat are you feeding it from the Arduino?
Ron
Foong Lik Wei
Joined Feb 16, 2015
Dear Don,
A digital signal from Arduino feed to LM386 (Power Audio Amplifier) first and then the LM386 connect to the speaker. Therefore, the output of speaker is depends on the digital signal from the Arduino board.
Regards
Foong
