The IN0 pin of ADC0808 shows 2.5volts with no connection to the sensor
Discussion in 'Embedded Systems and Microcontrollers' started by KumaraGuruparan, Aug 20, 2007.
  1. KumaraGuruparan
    Aug 20, 2007
    19
    hi,
    i have interfaced ADC0808 with AT89c51 and i see the IN0 pin of ADC shows 2.5V. I have not connected any sensor to it.Some say that the pin is open drain and hence there is 2.5V. I like to know whether it usually shows this voltage or is there any problem with my circuit.
    Also I have designed circuit with sensor. I use a platinum 100(PT100) RTD for sensing temperature and designed it such a way that the output voltage varies from 2.5V-5V. But the actual voltage range I need is 0-2.5V.can anybody help me how to scale the voltage from 2.5V-5V to 0-2.5V.
    Kumara.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    It would help if you could provide a schematic of the section of circuitry relating to you question.
    hgmjr
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    The IN0 pin is the first of the 8 inputs to the A-to-D convertor. Assuming that you have something connected to the input then the 2.5 volt signal is originating from that signal source.
    A schematic will help shed more light on an explanation.
    hgmjr
  4. KumaraGuruparan
    Aug 20, 2007
    19
    I get the voltage without connecting any sensor.The pin is open.
    I have attached the circuit.Kindly check it
  5. KumaraGuruparan
    Aug 20, 2007
    19
    I have attached the circuit.Kindly check it.....
    If I connect LM35 sensor to this cicuit i get the correct output(0-100). But please help me in connecting a PT100 RTD with ADC0808.
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    I don't have the software to view your schematic.
    I can however say that the voltage level on an input that is not connected to a signal source is generally not a problem. It is a good engineering practice to tie all unused CMOS inputs to ground or the positive supply using a resistor between 10K and 100K.
    hgmjr
  7. KumaraGuruparan
    Aug 20, 2007
    19
    Sir, I have attached the schematic in word format. Kindly check it.
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    I would suggest that you put a 100K resistor to ground on all of the ADC0808 analog inputs just to avoid leaving them open when nothing is connected.
    What is the value of zener Z1?
    hgmjr
  9. nanovate
    Distinguished Member
    May 7, 2007
    665
    You can use an instrument amplifier like INA118. How much resolution do you need? 8-bits may not be enough.
    edit: RTD is a pretty expensive way to go if you are going to feed it into an 8-bit A/D. What are your resolution, accuracy and range requirements? You might be better off w/NTC type.
  10. Distort10n
    Dec 25, 2006
    429
    You can just tie the inputs to Vcc or to GND as long as those potentials are within the ADC's input common-mode range. A resistor is a bit of a waste since it will serve to drive up cost, and space. If it is noise that is a concern, a resistor will do nothing to help anyway.
  11. KumaraGuruparan
    Aug 20, 2007
    19
    The value of zener is 2.2V
  12. KumaraGuruparan
    Aug 20, 2007
    19
    The value of zener is 2.2v
  13. nanovate
    May 7, 2007
    665
    I'd recommend using a voltage reference IC instead of a zener for Z1 unless you are accounting for the zener's tempco.
  14. KumaraGuruparan
    Aug 20, 2007
    19
    sir,
    I have sent the sensor circuit. the (Vin Adj Gnd) in the ckt is LM317..
    • Doc1.doc
      File size:
      118.5 KB
      33
  15. nanovate
    May 7, 2007
    665
    That circuit will cause the RTD to self heat thus killing a lot of your accuracy. What you want is to put a very small constant current through the RTD-- small so that you do not heat it up. The LM317 can be configured as a constant current current source. If I remember correctly the datasheet has an example circuit for using it as a current source.
    Here is a classic appnote that might help you:
    http://ww1.microchip.com/downloads/en/AppNotes/00687b.pdf
    I forgot to mention that you can use a simple Wheatstone bridge to interface your RTD also. Just feed it into an instrument amp like the AD627 or AD8555.
  16. hgmjr
    Jan 28, 2005
    9,030
    214
    Did you purchase the 3-terminal or 4-terminal version of the PT100?
    hgmjr
  17. KumaraGuruparan
    Aug 20, 2007
    19
    3 terminal version of PT100.
  18. KumaraGuruparan
    Aug 20, 2007
    19
    I have tested the circuit in page 4 of the above link. but the voltage varies only between 0.78V to 1.04 volts. the resistances r3, r4, r5, r6 are not mentioned and i put 100 k for all the resistors. for c3 and c4 i put 0.1uf.
    Should i make any change in this resistances to get full voltage range.
  19. hgmjr
    Jan 28, 2005
    9,030
    214
    Could not work with the link you provided in the title of the post.
    Here is a link to the document I found with google.
    hgmjr
  20. KumaraGuruparan
    Aug 20, 2007
    19
    What value should i put for R3, R4, R5, R6, C3, C4.
