The Finishing Touches to a Project
Discussion in 'General Electronics Chat' started by Jswale, Dec 4, 2015.
  1. Jswale
    Jun 30, 2015
    121
    6
    Hi!
    I recently embarked on making a snooker scoreboard for a gift...
    I have built it, coded and done the enclosure...however the enclosure has a few small scratches or the holes are not completely round (which you will be able to see in the pictures).
    Anyone any advice on how to touch these up? maybe with a varnish or round stickers over the holes or some little trick?
    Cheers
    JSwale
  2. ISB123
    May 21, 2014
    1,240
    531
    There are no pictures.
  3. Jswale
    Jun 30, 2015
    121
    6
    Are they not under the attached files?
  4. Jswale
    Jun 30, 2015
    121
    6
  5. AnasMalas
    Member
    Nov 27, 2015
    66
    10
    I dont really know of a good method (probably some spray expert knows) but maybe you could get a polished finish with some fine sandpaper.
  6. ISB123
    May 21, 2014
    1,240
    531
    Try wet sanding with high grit paper 1000+grit.
  7. Sensacell
    Jun 19, 2012
    1,184
    277
    Really not much to do without a major effort.
    If you try to sand it, you must sand it down deep enough to get under the scratches, then use finer grits to bring it back to a luster of sorts.
    But you cannot do this to just the scratched area- you need to sand the entire thing if you want it even- spot sanding will look horrible.
    Not worth the trouble.
  8. dl324
    Distinguished Member
    Mar 30, 2015
    3,379
    651
    Try filling the scratches/scuffs with black shoe polish, then buff. Or get some auto paint scratch repair cream; black is a standard color. Process is the same as with shoe polish.
    You can use a strain relief to cover up most of the hole with the cable in it, and provide some strain relief. Would be better to use a grommet, but it may be too late for that if you can't get one end of the cable through it.
    For the oversized panel cutout issue, use a black marker to cover visible edges/gaps. Could also try removing the LCD panels and using black electrical tape to cover the irregularities.
  9. Lestraveled
    May 19, 2014
    1,957
    1,218
    I have used Futura acrylic floor finish to reduce scratches on plastic. They don't go away, they are just less visible.
  10. BReeves
    Member
    Nov 24, 2012
    412
    64
    Start over with a new box and be more careful.
    Sensacell likes this.
  11. Jswale
    Jun 30, 2015
    121
    6
    I took your advice and changed the back of the enclosure but kept the front because that looked good enough. Just got one picture to show anyone that's interested of the final thing.
    It is controlled with a Youview remote and is powered via the USB on the Arduino and an Apple Iphone charger plug.
    Regards
    JSwale
    Sinus23 and ISB123 like this.
  12. AnasMalas
    Member
    Nov 27, 2015
    66
    10
    Now if the old one is scrap try polishing it with sand paper as an experiment. you never know if it would benefit you in future...
    atferrari likes this.
  13. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    You might daub the screw heads with some satin black paint. You could also daub some satin black on the scratches on the back then polish them down with successively finer grained sandpaper on a rubber block. Start with 600 grit and go down to 1200. Then rub in some armor-all, Meguires or some other plastic treatment.
    But seriously. You made this, it works and now you are giving it as a gift. WELL DONE! Personally, I think that the scratches et al add to the value of your work. Want a perfect finish? Buy it at WalMart - wait.. they don't sell that?
    Merry Christmas!
    Jswale and AnasMalas like this.
  14. #12
    Nov 30, 2010
    16,704
    7,354
    We had good results with Turtle Wax at one place I worked...including the faces of the meters.
  15. hp1729
    Nov 23, 2015
    2,099
    233
    Contact paper, like that used to line kitchen cabinets.
