Oops... never drink and post on AAC... my momma always warned meIf I still have the same number of fingers, it seems that the 8th planet is Neptune.
Posting while intoxicated. The software has a module for that.Oops... never drink and post on AAC... my momma always warned me
Did you remember to take your thumb out of ...?If I still have the same number of fingers, it seems that the 8th planet is Neptune.
This observation of yours explains A LOT about this place...Whuuuuaaaatttt? We're not supposed to drink before posting???
One of the most famous things Richard Feynman ever said was, “The first principle is that you must not fool yourself – and you are the easiest person to fool.” When you come across an announcement like the one made by NASA Spaceflight a week ago: that NASA has made a successful test of the EM Drive — a propulsion engine that uses no propellant, seemingly violating one of the most fundamental laws of physics, while warping space in the process — you’d better make sure you aren’t fooling yourself.
http://www.iflscience.com/no-em-drive-will-not-lead-warp-travel-any-time-soon“My insight is that the EMDrive is complete crap and a waste of time,” Carroll tells io9. “Right there in the abstract this paper says, ‘Our test campaign can not confirm or refute the claims of the EMDrive’, so I’m not sure what the news is. I’m going to spend my time thinking about ideas that don’t violate conservation of momentum.”
One of the outlandish claims for the EM Drive is that it provides propellant-less propulsion but, again, this has never been proven. As the researchers explained in their paper: “Our test campaign can not confirm or refute the claims of the EM Drive but intends to independently assess possible side-effects in the measurements [sic] methods used so far.”
Apparently it has very cautious defenders:
And ferocious detractors:What it actually does is produce a tiny, tiny amount of thrust via a method that’s not entirely understood.
“...[They] don’t say that they’ve validated the drive – just that they can’t explain where their teeny tiny thrust signatures are coming from.”
...It means that the EM Drive remains nothing more than a form of propulsion with a really low amount of thrust that scientists can’t completely explain. That won’t stop a host of places from telling you otherwise, though.
Just remember, if there’s no peer-reviewed research saying how it works (there isn’t) or experimental evidence of it producing high thrust (again, nope), then take everything with a hefty pinch of salt.
...when looking at previous EMDrive experiments, Davis noticed that the alleged thrust was generated slowly, and not instantaneously, when the electrical power was switched on.
...“This is a direct indication of a thermal effect in reverse (heating versus cooling), which produces a clear false positive thrust signal,” says Davis. “Tajmar has to account for and reconcile this fact as well in his data analysis which he apparently did not discuss in his paper. This would be another nail in the coffin against the existence of any real definite momentum violating thrust produced in the microwave cavity.”
...Critics of the EMDrive, of which there are many, say it’s all poppycock.
If your investment is selling ads in SCI-POP articles then you will make a bundle.You mean to tell me I'm not going to get rich from my investment?
You must be talking about, "upsidaisium". It was discovered years ago, they even had a TV documentary that lasted many weeks on it, back in 1960 - 61.In the model I study, gravity is not a fundamental property.
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Jeff Child
