Have you been messing with the account permissions? A google search is better than an AAC search in these matters.
In general Win 7 have been running smoothly (almost) on 3 consecutive installs, apart from some screen saver and user account privileges issues. In my opinion it's the most successful MS OS so far.
U still don't get it.....
This happened before, as a matter of fact this happens only to me....Googling hits ****.
The screen with the red cross says, "Network path not found".
This is a fresh install, I tried disabling, enabling, LAN and I even installed a PCI LAN card. I have installed Win 7 with and without network connected, and yet the doggone thing refuses to log in to the desktop.
It's not like that this is my first time, I have installed Win 7 on several PC's with all different CD's.
But I Just can't figure out why I am getting this error on this particular PC.
By the way...I never enter any passwords. to check I did but to no veil.
Another really good site I use for my computer issues is "Major Geeks". They use the same software, so you will be comfortable with them. There are some very high level computer types on this site.
Google up the 'chip set' you are using. It may be the computer has a set of bios chips which are not compatible with the new OS. If the chips are listed as 'supported', then you may have to flash them to a newer rev level. (IF it is a chip set problem-sounds suspiciously like it is)
