The Diode, are they mostly use for safety nets?
RyanD
Joined Jan 14, 2010
30
Most of the circuits I've been studying to learn from have diodes for two reasons. The first(most common) is to make sure current doesn't flow the wrong way and break something. The second is to drop the voltage a little(why not just use a resistor?) So, are these the main reasons to use one, are diodes necessary or just a safety precaution?
jpanhalt
Joined Jan 18, 2008
11,087
The voltage drop across a resistor is directly proportional to the current. The drop across a diode is not and is much less affected by the current. See this graph from the 1N4148 datasheet:
John
Bernard
Joined Aug 7, 2008
5,784
Most usage is for one way current control, power rectfication, reverse polarity protection, implementing diode OR gates & other uses that I can not think of.
Wendy
Joined Mar 24, 2008
23,421
Not just OR gates, they also make AND gates.
I regularly use diodes as voltage references, similar to zeners. They are relatively stable, other than temperature. They are predictable enough to be used as temperature sensors.
