The differences of MAX232...
Discussion in 'The Projects Forum' started by kevy, Nov 27, 2006.
  1. kevy
    Nov 22, 2006
    6
    What is the differences of MAX232, MAX232N, MAX232CPE and MAX232CP?
    As I read the data sheet for MAX232N, it is using plus and minus 8.5V dc for pin 2 (Vs+) and pin 6 (Vs-).
    And some MAX232 use 3.3V or 5V...
    Can I use 5V and ground for MAX232N.
    If yes, how to use it?
  2. pebe
    Oct 11, 2004
    628
    The MAX232 is intended to be run from a 5v supply. The +/-8.5v pins you mention are generated from within the chip so that TTL levels can be converted to RS232 levels, which go above and below 0v. Page 7 of this link shows its typical application.
    http://lwww.ece.uidaho.edu/ee/classes/ECE341F06/datasheets/MAX232.pdf
    It has two TTL to RS232 converters and two RS232 to TTL converters.
    As far as I know, the ‘N’ or other suffix denotes the type of package.
  3. ScarEye
    Member
    Nov 24, 2006
    24
    kevy,
    If you don't mind me asking, what application are you trying to use this chip for ?
  4. sci-3d
    Aug 22, 2006
    51
    This chips are used in MCUs serial commutation. For example interfacing Computer with 8051.
