the design knock off nigel
takao21203
Joined Apr 28, 2012
3,702
Every manufacturer can take precautions to people copying off the design quite easily.
-Twisted assembler produced by compilers, you don't need a code protect. If you use the max. density of the memory with programming tricks in C, the assemler code from that will look funny :)
No one wants to work that out manually in assembler. Even if you get an idea how it works, you really would not want to.
-Unusual analogical circuit elements.
For instance I get random numbers from thermal noise. Never a same code again.
Copying off designs in a productive way means only to use some aspects for your own product.
It is OK to do it.
