The dell power supply D3D1C makes very loud noise.
Discussion in 'General Electronics Chat' started by Scott Waschlerner, Feb 19, 2016.
  1. Scott Waschlerner
    Jan 22, 2016
    Mods Edit :
    Please don't hijack other member's thread, now you have your own.
    This thread was split from What causes a computer power supply to fail?
    Hello! Interesting information! I have not had PSU breakage yet but it makes very loud noise. I have installed this model about 5 months ago (http://hardware.nl/power-supply/dell/d3d1c.html) and I think it is too short time to be broken. But what can I do with this noise? Is the replacing the only one solution?
  2. Dodgydave
    Jun 22, 2012
    5,166
    776
    Whats making the noise, the fan or is it transformer whistle, can you record the sound and post it?
  3. GopherT
    Nov 23, 2012
    6,330
    4,069
    I would check the fan for a toothpick or some other long slender item lost into it. Or, check if it is a piece of paper flitting. Also, a chunk of fan could have broken off it is was molded badly (or struck something). That could be a vibration.
    These new supplies run at such high frequencies, there is little if any transformer steel to be buzzing.
    Other option is that it is cutting out from some thermal or overload issue and turns on again as soon as the cut-out is stopped.
    As DD suggests, a video or audio with the noise would be great.
    Finally, it is a fairly low power supply for that high cost. Was the original such low power too? If not, you might be overloading this little supply (265 watt). Any video card added/upgraded that would draw more than original power?
