Your question is unclear. Do you want to swap the transistors in a typical CMOS inverter? Or do you want to replace the NMOS and PMOS devices with something else?How can i build inverter, changing places transistors NMOS and PMOS?
The positions of the PMOS and NMOS transistors can't be swapped.Yes I want to swap the transistors in a CMOS inverter,but how to connect that it were an inverter
Are you referring to how to layout a diode in an integrated circuit using N diffusion and P diffusion?how to build the layout of diode without transistor?
Pwell or nwell process? Do you want diode on the substrate or in a well?
Draw P diffusion in an nwell, that's the diode anode. Draw well tap in the nwell, that's the diode cathode.nwell
Thread starter | Similar threads | Forum | Replies | Date |
J | Crystal oscillator using discrete CMOS inverter ? | Digital Design | 17 | |
B | VTC curve and the delay time of CMOS inverter | General Electronics Chat | 1 | |
current in cmos inverter | IC Design | 2 | ||
CMOS inverter as amplifier, current limiting | General Electronics Chat | 17 | ||
CMOS vs NMOS inverter | Analog & Mixed-Signal Design | 11 |
by Aaron Carman
by Aaron Carman
by Aaron Carman
by Duane Benson
