The circuit of 5V/50mA wind turbine and solar panel in series or parallel to output 12V.
Discussion in 'Power Electronics' started by micro1, Sep 15, 2016.
  1. micro1
    Feb 22, 2015
    53
    if I have 10 Pieces from solar cell and I have 10 Pieces from wind turbine everyone from solar and wind the out voltage equal 5V and current equal 50mA.
    if I want to do a circuit in series or parallel , how I can do the circuit or (contact the solar and wind ) 12v from 10 Pieces solar cell and 10 Pieces wind ?
    ( this is not homework)
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I have no earthly idea what you are talking about. What does "10 Pieces from solar" even mean? Show a diagram or a schematic.
  3. micro1
    Feb 22, 2015
    53
    I have 10 pieces from solar cell , every pieces size is 7*3 cm and 5v ,50mA
    how I can connect 10 pieces for solar cell and wind turban parallel or series , but the max Voltage equal 12v
  4. micro1
    Feb 22, 2015
    53
    i want do schematic for my circuit equal 12v use 10 pieces from solar cell and wind turbine
  5. Dodgydave
    Jun 22, 2012
    5,171
    778
    If i understand your idea, you want to create 12V from solar panels in series with 5V panels,, so two panels in series is 10V, three in series is 15V!!!
    micro1 likes this.
  6. micro1
    Feb 22, 2015
    53
    ok noted
  7. wayneh
    Sep 9, 2010
    12,405
    3,256
    The answer depends in part on what output you want, and on the details for each component. You haven't told us either.
    The simplest way to connect different power sources is to place a blocking diode on each one, between the supply and the load. This ensures no current flows from the stronger supply into the weaker ones.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Stop calling them pieces and start calling them "solar panels", that is what confused me. Nobody calls them "pieces", that term could mean anything.
    cmartinez and micro1 like this.
  9. BR-549
    Sep 22, 2013
    2,184
    421
    And you have 10 wind turbines too?
  10. hp1729
    Nov 23, 2015
    2,106
    235
    5 V outputs in series increases in multiples of 5V. N way to end up with 12 V. 15 V and regulate it down to 12 V? 3 in series, 3 of those sets in parallel and one spare?
  11. ScottWang
    Aug 23, 2012
    4,934
    777
    Why don't you just ignore the from or change to of as 10 Pieces of solar cell, and why you used "pieces" compared to "solar panels"?
  12. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I don't understand what you are saying Scott. Could you please express this thought with more clarity?
  13. ScottWang
    Aug 23, 2012
    4,934
    777
    The TS said ------- if I have 10 Pieces from solar cell.
    You can treat it as -- if I have 10 Pieces of solar cell
    English is your native language, so I think you can guess that, there is no problem about it.
  14. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I apologize to you Scott and the rest of the community, but my ability to parse fractured English is not quite what you imagine it to be. It may have been obvious to you and it may have been obvious to others, but it wasn't obvious to me; that is why I asked for clarification.
    ScottWang and djsfantasi like this.
  15. ScottWang
    Aug 23, 2012
    4,934
    777
    I'm not sure what's your situation, but to me when I met the foreigners in Taiwan, I will guess what they said in Mandarin or Taiwanese and what they are trying to express, and I would spoke out the correct word or sentence to them and asked them were those they were trying to say?
  16. Papabravo
    Feb 24, 2006
    10,340
    1,850
    OK Scott, I will stipulate that you are a wonderful human being, a real mensch.
  17. MrSoftware
    Oct 29, 2013
    545
    133
    I'm always impressed by people who speak more than one language, even if the second language is somewhat broken. I've become very good at figuring out what non-native English speakers are trying to say, and it's actually fun to try to figure it out sometimes. It's often very logical, such as in this case. "10 pieces" is a very logical description of 10 panels.
    Anyway, if I'm reading it correctly, you've got 10 solar panels and 10 wind generators, each of which will give 5v and 5mA output. Your goal is 12v output.
    1. What is more important to you, simplicity or efficiency?
    2. Is your goal to use the power directly or to store it in a battery?
    3. Are there data sheets available for your equipment?
  18. ScottWang
    Aug 23, 2012
    4,934
    777
