The capacitance of capacitor and energy.
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, May 27, 2015.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    If the capacitor has 100 v limit and its capacitance is 1uF ,this mean that the max. energy is 1/2CV*2=5 m J
    or I can put more energy on the cap.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    milli G ????
    0.5mJ is all you can put in it...
  3. ian field
    Distinguished Member
    Oct 27, 2012
    4,458
    792
    You can't even cheat with electrolytics - if you supply a current limited higher voltage just under the critical leakage point, the oxide dielectric will form thicker to withstand a higher voltage - but the effectively greater spacing between the plates results in proportionately lower capacitance.
  4. ErnieM
    Apr 24, 2011
    7,440
    1,628
    If this is a real world capacitor don't put 100V across it, not if you want the cap to survive for the long term.
    75V is better. I would limit it to 50V.
  5. ian field
    Oct 27, 2012
    4,458
    792
    If its an electrolytic; the applied voltage is what keeps it formed, at a lower voltage the electrolyte very slowly etches away the oxide dielectric - if you then suddenly apply the full rated voltage without first re-forming the capacitor, it'll probably break down.
    As a result of the oxide dielectric getting thinner, the capacitance increases.
    If the TS is going to the trouble of calculating the energy for a given voltage/capacitance, the exact value of capacitance may be important.
  6. djsfantasi
    Apr 11, 2010
    2,911
    881
    Without parentheses, it is easy to misinterpret your equation. I am assuming that you mean \frac{1}{2}CV^{2}
    I get 5 mJ
    My work is shown below...
    10^{-6}*10^{4}*\ .5=.005J\ or\ 5mJ
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    Yep...
