The Black Box Test
Discussion in 'Homework Help' started by tahayassen, Apr 1, 2013.
  1. tahayassen
    Apr 1, 2013
    1. The problem statement, all variables and given/known data
    So in the future, I will have to find out what is inside a black box:
    2. Relevant equations
    3. The attempt at a solution
    Here is the solution to it: http://drunkenengineer.tripod.com/Year1/ele202/blackbox/blackbox.html
    The issue is that I'm having trouble understanding why the guide uses those techniques/tests.
    I understand the ohmmeter test. The reason why the ohmmeter would give a reading of infinity if it is a rc-series box is because capacitors act as open circuits to DC.
    Questions:
    1. Phase Shift Test: we have to make a circuit. It consists of a signal generator, an oscilloscope, a black box, and the attached symbol. The attached symbol is just a signal generator, right? And functions generators are the same as signal generators, right? The shape of the circuit looks weird. What is the motive behind the circuit designed like this?
    2. Inductor test: I don't understand the circuit diagram. A and B are two different channels, right? So where would the other ends of the channels be connected? What is the motive behind the circuit designed like this?
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    Look up the term "Lissajous" for more information.
