the battery is broken or if the charging system is defective in a laptop Dell d4030?
Discussion in 'General Electronics Chat' started by forone, May 29, 2012.
  1. forone
    May 29, 2012
    the battery is broken or if the charging system is defective in a laptop?
    Hello
    My IPC laptop Dell Inspiron N4030 can charge the battery on AC power only up to about 23% and
    only very slowly. The unit is about 3 years old.
    Now the question is: the battery is broken or if the charging system is
    A new battery will cost a lot of money (110 €), so I'm eager to obtain
    some experience with experts.
    In addition, I found three shops to buy a laptop battery,
    1. http://www.elecachat.fr/dell-inspiron-n4030.html
    2. http://www.bateriabaratos.com/dell-inspiron-n4030.html
    3. http://www.pcbateria.es/dell-inspiron-n4030.html
    will you suggest me which one of the better battery
  2. #12
    Nov 30, 2010
    16,679
    7,322
    I think it's the battery. Besides, much easier to try a different battery than to try to repair inside a laptop computer.
    All those batteries look the same to me.
  3. mlog
    Member
    Feb 11, 2012
    276
    36
    Yep. The Dell laptop batteries are notorious for going bad after a couple of years.
  4. maxpower097
    Feb 20, 2009
    795
    388
    Did it all the sudden go bad or was it a gradual decline then kaput? Or were you getting 3-4 hours on a charge then all the sudden your laptop will only charge to 23%? Or did you used to get 3-4 hours a charge, then last year you were getting 1.5-2 hours a charge, then this year your getting 1-1.5 hours a charge then kapow, won't charge anymore?
  5. maxpower097
    Feb 20, 2009
    795
    388
    Also I don't know what the conversion rate from 1L to $1 but if your gonna have to pay 110L for a battery consider a newer faster machine will cost you around $399 right now with an i5 core, 6GB, etc...
  6. #12
    Nov 30, 2010
    16,679
    7,322
    Frustration about batteries costing so much that it is reasonable to replace the whole computer! :(
