The battery equivalent internal impedance equation
Discussion in 'Homework Help' started by Marius Balandis, Apr 26, 2016.
  1. Marius Balandis
    Apr 26, 2016
    Hello, long story short: I need to create a model of Li-Ion battery and i'm stuck on calculating the battery equivalent internal impedance. The thing is, I don't know the equation or even how to make one. However, I have a circuit drawing:
    Could someone explain how to calculate or write down an equation for battery equivalent internal impedance
  2. Kermit2
    Feb 5, 2010
    3,854
    968
  3. Marius Balandis
    Apr 26, 2016
  4. WBahn
    Mar 31, 2012
    18,093
    4,920
    What is your starting point? You calculations are going to use what information as inputs?
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What makes you think there is a way to calculate it? Maybe you can't pin down enough information to make a meaningful calculation.
  6. MrAl
    Distinguished Member
    Jun 17, 2014
    2,573
    522
    If all you have is that circuit then it is quite easy to do. You do have to know how to combine impedances that's all.
    If we number all the resistors as R1, R2, R3, R4 from left to right, and the two C's as C3 and C4 from left to right, then we can follow this procedure:
    1. Combine R4 and C4 into one impedance, Z4.
    2. Combine R3 and C3 into one impedance, Z3.
    3. The total impedance is then R1+R2+Z3+Z4, except you may want to simplify the result.
    To combine two parallel impedances into one, we can use:
    Z=Z1*Z2/(Z1+Z2)
    If you have never done this before then we'd have to go into that next.
