The assembler directive DS can't take effect in IAR IDE
Discussion in 'Embedded Systems and Microcontrollers' started by zhangyong, Mar 12, 2011.
  1. zhangyong
    Mar 12, 2011
    Hi, Who can help me?
    I want to reserve memory space for 128 bytes (0x100) with the directive DS, but DS can't take efffect. my code likes the following:
    ASEGN datas:IDATA,0x20
    result DS 0x100
    temp DB 0xFF,oxFF
    the right result is that the two 0xFF should locate 0x11F of internal memory, but they locate 0x20, that is, the directive DS does not reserve any space, the space should be reserved still can be occupied!
    why?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    For starters 0x100 is equal to 256, not 128. The size of the IDATA section is only 128 bytes. So in effect you said reserve twice as much space as the size of the section and then allocate two more bytes. It should have thrown an error, but I guess it gave you a pass an optimized away the allocation with no "purpose". RTFDS man!
