'The art of electronics' is a worthless piece of garbage! !!
Discussion in 'General Electronics Chat' started by imbaine13, Feb 11, 2015.
  1. imbaine13
    Oct 6, 2013
    62
    I recently acquired The art of electronics and I have discovered it really wasn't worth it, especially considering it doesn't seem like a self study book (contrary to popular belief). It has been two years since I started learning electronics and I have built and prototyped a lot if circuits but I still can't go a page if this book (chapter 2) without thinking too hard and eventually giving up that section out of frustration. I am currently trying to learn how to build relatively good (thd <0.01) audio amps and I thought this book along with 'high power audio amplifier construction manual - G. Randy Slone' would do the trick but both have terribly disappointed me. Might anyone have any idea where to start with audio amplifiers (something simpler)? Perhaps an actual self study book and not something pretending to be one!
  2. JoseBarbosa
    Jun 13, 2014
    For me "The Art of Electronics" is one of the best books I ever bought!
    Sensacell, shortbus and absf like this.
  3. joeyd999
    Jun 6, 2011
    2,759
    2,943
    It was my bible for the early part of my career.
    It has gotten a bit long in the tooth, though.
    absf likes this.
  4. GopherT
    Nov 23, 2012
    6,339
    4,084
    Well, first, you should post your question on All the sub-forums instead of just two.
    Then you should realize there are several types of books.
    Some include,
    How to - not much in terms of theory, they just show you how to get it done. Step by step
    Reference Book (tables of data, and brief explanations, references of other texts where you can find more information)
    General Textbook (kind of an introduction to a subject that gives you the vocabulary and basis to discuss more advanced topics)
    Sub-topic specific textbooks (digs into the details without reviewing the basics)
    The Art of Electronics is a hybrid of General Textbook and reference book all in one. My rule of thumb, tools that do more than one thing are ok at each but usually not great. Same applies to this book, but if you read the intro (or Foreward?), it specifically says it is intended for non-engineers (chemists, biologists, geologists, ...) to get them started in building (or even understanding the capabilities) of electronic measurement and testing. So definitely the wrong place to learn about mid-quality audio.
    In general, it takes an expert to design an audio amp with 0.01 % thd. Recently, it has been suggested that it takes 10,000 hours of study and experimentation to become an expert (about 5 years of 40-hour weeks). In other words, the electronics companies don't hire hobbyists with 2-years of experience to design their consumer amps.
  5. tracecom
    Apr 16, 2010
    3,879
    1,396
    absf and joeyd999 like this.
  6. MrChips
    Oct 2, 2009
    12,652
    3,461
    We're very sorry that "The Art of Electronics" does not meet your needs and expectations.
    Perhaps "Electronics for Dummies" is what you need.
    If you are looking for DIY audio projects, look at Rod Elliott's site:
    http://sound.westhost.com/
    DerStrom8, absf, Reloadron and 2 others like this.
  7. Brevor
    Apr 9, 2011
    282
    56
    I own a copy of "The Art of Electronics" I borrowed someones copy for a few weeks and it was so good I bought my own. It's been several years since I last opened it so I don't remember exactly how the subject was presented, but I found it very useful. Perhaps already having an electronics education made it easier to use.
    Edit: I pulled my copy off the shelf and looked through chapter 2. (transistors) To me it seems to explain the subject very well. Maybe you could try posting some of your questions here about the parts you don't understand. There are a lot of amplifier experts here.
    absf likes this.
  8. joeyd999
    Jun 6, 2011
    2,759
    2,943
  9. atferrari
    Jan 6, 2004
    2,674
    785
    THAT is the point.
    After my divorce, I realized that things I consider a failure, are so not because they developed wrong but because they did not fit my expectations. That simple.
    But "garbage"? In a title? Google "overshoot".
    absf, cmartinez and MikeML like this.
  10. sirch2
    Jan 21, 2013
    1,008
    351
    Sell your cleverness and buy bewilderment.
    Cleverness is mere opinion, bewilderment intuition. - Jalal al-Din Muhammad Rumi
    Sometimes, when my views go against the opinions of the vast majority, just sometimes, occasionally, I wonder if they may be right and I may be wrong.
    DerStrom8, absf, MikeML and 1 other person like this.
  11. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    I had a couple of issues with the A of E. was the misuse of the power common displayed throughout the book by the use of the earth ground symbol instead of the more correct Logic or signal common symbol.
    And also the fact that I could not find either recommended schematic layout methods or a list of electronic symbol definitions from any standard.
    Max.
  12. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,709
    1,301
    Hmmm... We use your Earth Ground symbol for signal ground, your Chassis Ground symbol for Earth Ground, and your Signal Ground for negative power supply rails. If signal gnd is tied to earth gnd, the earth gnd symbol is used. In our systems the chassis always is earth grounded due to UL and MIL rules, but signal gnd often is floated from earth.
    ak
    absf and shortbus like this.
  13. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    The symbols are clearly defined in various standards both N.A. and EC.
    The problem as I see it is when a symbol is defined and the definition is disregarded, the symbol becomes meaningless.
    It may not cause a problem when a circuit is confined to one isolated circuit, but when power circuitry is included such as a Earth grounded supply, it could be dangerous if the symbols are taken literally and wired as such.
    There was an example here just over a week ago where someone had shown a circuit using the earth ground symbol, but it would have been catastrophic if the circuit had actually been referenced to earth ground.
    Max.
    Lundwall_Paul, sirch2 and cmartinez like this.
  14. cmartinez
    Jan 17, 2007
    3,700
    2,802
    I liked the Grounds for Divorce icon...
  15. tracecom
    Apr 16, 2010
    3,879
    1,396
    Maybe I need to start putting my change in a piggy bank. $114 :eek:
  16. Veracohr
    Jan 3, 2011
    560
    77
    imbaine13 likes this.
  17. MachineHum
    Member
    Nov 3, 2014
    70
    That book was the best thing I've even bought...
  18. imbaine13
    Oct 6, 2013
    62
    I appreciate all you guy's input. sirch2, you might be right, but I have seen a number of noobies post a lot questions from AoE, which I'm confident proves my point. Why do so many electronics guys recommend the book to absolute beginners if it's so confounding anyway?
    I do recognise the author's effort to write such an extensive book but I would appreciate it if the concepts were more elaborate. I'm the kind if person that wants to understand every detail of everything, and this book isn't cutting it.
    Thanks Brevor. It's unfortunate I don't feel the same. I'm hoping things will eventually improve with time and more experience.
    I'd appreciate more suggestions on audio amp books.
  19. imbaine13
    Oct 6, 2013
    62
  20. joeyd999
    Jun 6, 2011
    2,759
    2,943
    And I've seen a bunch of noobs post a lot of stuff I'd be embarrassed to repost here. Noobs are like that. That's why they're noobs.
    absf and GopherT like this.
