Everything else seems ok with it, the LED TV works, TV signal amp works, my phone charger works.
The computer though it boots up, the GPS wont find satellites, and running program opencpn goes me error like jack server not running.
And then the PC refused to boot up at all, so I disconnected all the internal cables and hooked it all up, then it was booting again off this MSW inverter.
Sometimes the LCD monitor has vertical lines appearing which goes away if you move the window.
I was wondering if the thing is putting out electrical noise?
Would a better newer ATX power supply be a solution?
I thought switching power supplies were not compromised by MSW inverters?
If I run the PC off the generator or off the Minuteman UPS inverter, it works fine with no issues at all.
