thanx AG
Discussion in 'The Projects Forum' started by mustashi113, Dec 22, 2008.
  1. mustashi113
    Dec 22, 2008
    9
    here's what I did I built a hydrogen generator
    I hooked it up to 120v ac a dimmer switch and a full wave rectifier , At no load the voltage was 106 volts DC when I turned up the dimmer slowly I got Great results at about 5 amp load and better as It went up but I was happy with 5 amp load
    now what I'd like to do is going from the alternator of a car to a inverter which i have so It changes from 12 v dc to 120 v ac then thru a recrifier which will give me 106 volts dc but I prob won't have the amperage I want
    my inverter Is A 800 watt inverter
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    800W at 14V is 57 Amperes, and 6.66 Amperes at 120V (the current of the beast! :eek:) if it's 100% efficient, which I will guarantee that it is not. 84% efficient is within the realm of realism, which would be 5.6A output for 57A input.
    Your vehicle's electrical system will need a rather hefty upgrade, unless you enjoy driving around with no headlights, radio, heater, and a dead battery.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Can you quantify the underlined term? John
