Testing very old SRAM chips
Discussion in 'Programmer's Corner' started by eyewonder, May 22, 2011.
  1. eyewonder
    Oct 21, 2009
    I need to be able to test some VERY old SRAM chips - HM-6508-9. These are 1K x 1 chips, 16 pin.
    Anyone know of an old (or new) tester that can handle these ancient things?
    Cheers,
    Steve
  2. t06afre
    May 11, 2009
    5,939
    1,222
    I would think this would be a simple task for a microcontroller application. It would not require very fancy programming at all
  3. eyewonder
    Oct 21, 2009
    I have thought about building my own tester, but most of my projects take a looooooong time to complete. This is for work, to repair a down machine that should be in production, making money for the company. So time involved is definitely an issue here.
    I was hoping that someone had had experience using an old programmer, possibly one of the old JDR MTC series, or Needham's.
    Cheers,
    Steve
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Once you are talking "money and company" it's probably best just to buy some new chips and replace them. Even if to replace some chips in banks (if there are a lot) as an aid to testing.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Those sound a lot like what the old Commodore PET's used to use, though I'm not sure. Those old computers used to go through RAM, and it didn't help they used a number that was later used for another chip. Made the old RAM unobtainium.
  6. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Exactly what are you testing? Just the ability to store and retrieve bits, or are you also checking timing?
    Either way it isn't hard to do. I did it a few years back with a 3-byte ISA card plus a few monostables to force the read and write timing to just under the spec minimums.
