Ancient but still very popular, the 555 gets a lot of attention in the forum here. "Don't work" is very popular.
If you are pretty sure of your circuit the next question is, "Is my LM555 bad?" Here is a circuit to test your LM555 and also makes a good lesson in how the LM555 works.
VCC is not specified so the LED resistors should be selected for about 2 mA. I haven't tried it on the CMOS version yet, but it should work.
Normally the Control Voltage line has a capacitor to ground. This pin goes to the upper tap of a three resistor voltage divider between VCC and ground. All three resistors are equal. So this line should be at 2/3 of VCC to indicate this pin is healthy.
