Testing Tantalum caps
Discussion in 'General Electronics Chat' started by Johndon2000, Jun 21, 2013.
  1. Johndon2000
    Jun 12, 2013
    25
    On a previous post someone mentioned that Tantalum Caps have high failure rates and are a good point to start when faulty finding... if a board has 40+ tantalum caps is there an easier method of testing the caps other than taking them all off 1 by 1 and measuring capacitance?!
  2. PackratKing
    Jul 13, 2008
    850
    216
    Unfortunately, you must pull up at least one leg
  3. RichardO
    May 4, 2013
    1,336
    429
    You can test ESR in some circuits without unsoldering the capacitor. If the ESR is too high then the cap is surely bad. If the ESR is OK there is still a chance the cap is bad -- for instance, the leakage may be excessive.
    PackratKing likes this.
  4. crutschow
    Mar 14, 2008
    13,479
    3,367
    It depends upon the other impedances connected to the capacitor at that node. If the other impedances are high then you may be able to measure it in the circuit. Otherwise you will need to lift one leg of the cap.
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    General tantalum failure is shorted, which should be obvious from a ohms test or the fact it has burn marks. ;)
    absf likes this.
