Testing semiconductor diode properties with a simple divider?
Discussion in 'General Electronics Chat' started by ElectricMagician, Sep 29, 2014.
  1. ElectricMagician
    Jul 26, 2012
    57
    Hello everybody,
    I want to test the properties of some diodes but I'm away from home.
    All I have at my disposal is a 19V laptop charger.
    Can I use it with a properly-rated pot to test the I vs. V properties of the various diodes?
    Also, the diodes being based on a SiC crystal, do I have to worry about UV exposure?
  2. MrChips
    Oct 2, 2009
    12,629
    3,452
    A 19V laptop charger is not much help unless it puts out AC voltage.
    You can make a simple curve tracer but you will need a low voltage AC source, a resistor and an oscilloscope that can display X-Y.
    ElectricMagician likes this.
  3. #12
    Nov 30, 2010
    16,684
    7,322
    Try faking the AC by just reversing the diode and measuring again.
