Testing J-K Flip Flop - HCF4027BE
Discussion in 'General Electronics Chat' started by PsySc0rpi0n, May 8, 2016.
  1. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Hi...
    I wanted to check if a couple of flip flops I have here are working properly. To accomplish that I was trying to verify the truth table but I'm having some issues in understanding how this works.
    What I already did was to check the datasheet which is here.
    In terms of connections I have the following:
    Pin 16 (VDD) --> 12V DC
    Pin 8 (VSS) --> GND
    Pin 13 (CLK1) --> 100Hz Arduino square signal with 5V of amplitude
    Now, the truth table works with J1 and K1 pins and will set Q1 and not Q1 to 0 or 1, accordingly, no??? Is that it?
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    The amplitude of the clock signal needs to be almost as high as the powersupply.
    In your case the powersupply is 12 Volts, but the clocksignal is only 5 Volts.
    Either amplify the clocksignal to about 12 Volts or use a supply voltage of 5 Volts.
    Bertus
  3. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Ok, I already changed it to around 5V.
    So, the first state:
    J1 -- GND
    K1 -- GND
    I have
    Q1 -- ~5V
    not Q1 -- "moving" square wave and after some time it changes to ~5V DC. Can't figure out why it changes to a "moving" square wave.
    J1 -- GND
    K1 -- 5V DC
    Q1 -- ~5V
    J1 -- 5V DC
    K1 -- GND
    Q1 -- ~5V
    J1 -- 5V DC
    K1 -- 5V DC
    Q1 -- ~5V
    I have no idea why this is happening... I can post a video or some pics to show it!
  4. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    At what levels are the S and R inputs?
    Bertus
  5. PsySc0rpi0n
    Mar 4, 2014
    1,191
    J1 -- 5V
    K1 - floating/not connected
    S1 - 0V
    R1 - 0V
    Q1 - square wave form
    not Q1 - square wave form (when Q1 is high, not Q1 is low and vice-versa)
