Testing Ir sensor 4 8051
Discussion in 'General Electronics Chat' started by jokester4u, Mar 18, 2014.
  1. jokester4u
    Nov 3, 2012
    26
    The sensor is giving only 1 how do i make it 0 . So it becomes off ...
      File size:
      67.6 KB
      21
  2. wmodavis
    Oct 23, 2010
    737
    150
    1 what? .
    Might have to do with the fact that the OP Amp output is grounded. Therefore the input to the 80C51 is also grounded. Is that what you want?
  3. bertus
    Administrator
    Apr 5, 2008
    15,800
    2,386
  4. jokester4u
    Nov 3, 2012
    26
    Yes !!!! It's grounded which makes the led glow. So my question is how do I get 1 input that will switch off the led. Meanwhile the sensor work both ways either 1 or 0 but unfortunately its working here as 0 only.
  5. wmodavis
    Oct 23, 2010
    737
    150
    It is impossible with the circuit you show because the output of U3A (LP339) is connected to the ground point and therefore cannot ever change from zero volts. It will always be zero volts. So since you state that YES!!!! you want it grounded you have what you want. Next question?
  6. jokester4u
    Nov 3, 2012
    26
    Or please let me know how to make a working IR sensor in proteus?
  7. wmodavis
    Oct 23, 2010
    737
    150
    For a starter DO NOT ground the output of the op amp. That prevents it from switching!
