testing for a failed MOSFET
Discussion in 'General Electronics Chat' started by jobertgalea, Feb 7, 2009.
  1. jobertgalea
    Nov 27, 2008
    11
    I need to know how can I test and identify if a MOSFET has failed or not due to high soldering temperatures. What can I do please, using just a simple multimeter? Thank you.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You should be able to read a diode junction from drain to source. The diode will be reversed biased in normal operation. All other terminals should check open.
    Do the check on a FET in a known good board so you have some idea of what readings to expect. Checking in circuit is always less clear than out of circuit because of alternative current paths.
