Is it possible / good idea, to test dc-dc converters in breadboard before ordering the PCB.
define "breadboard". If you mean a proto "plug" board, it will never work right. We used to build them on copper PC boards where we used a Dremel to cut the trace paths. If the makers give a layout, just go with that. They are usually optimized.Is it possible / good idea, to test dc-dc converters in breadboard before ordering the PCB.
Thread starter | Similar threads | Forum | Replies | Date |
K | Testing of a M5450B7 LED Driver | General Electronics Chat | 7 | |
J | Testing switch & DC to AC Converter | Test & Measurement | 15 | |
I | Buck Converter Testing | General Electronics Chat | 3 | |
A | Testing a I-V Converter | General Electronics Chat | 7 | |
S | Testing DAC(digital to analog converter) | Analog & Mixed-Signal Design | 22 |
