Testing an Inductor
Discussion in 'General Electronics Chat' started by EE_joe, Oct 17, 2005.
  1. EE_joe
    Oct 17, 2005
    ok, I'm an EE intern at a Mechanical Engineering firm, and need help.
    I've been assigned to test a circuit... simple enough
    well, it's been awhile since i've done circuit stuff. more of a communications guy myself (and not the circuits side).
    here goes:
    I wound this inductor (has power applications), with a tested value of 155 H.
    I'm supposed to hook this thing up to make sure it behaves the way it would in it's soon to be operating environment.
    I'm testing with a frequency of 1kHz, the real EE said I should choose a resistor such that there is about a 50V drop and a 3A drawn. Also, I'm supposed to vary the DC current to see how the inductor reacts.
    1) What resistance should I use?
    2) What is the expected behavior of the inductor as I vary the DC current?
    Now, don't make too much fun of me please.... I already get enough of that. Thanks, any help is appreciated.
  2. Overclocked2300
    Apr 24, 2005
    124
    Well if your resistor needs to be drop 50@3Amps then,
    R=V/I
    Where
    V=Voltage
    I= Current
    So
    50/3
    r=16.6666667 Ohms.
    An inductor resists any changes in current. Think about what happens when you give it the 1Khz Signal.
  3. mentaaal
    Oct 17, 2005
    451
    hey hows it going.
    em... i am a newbie myself and am interested in electronics but only just getting just getting over the fundamentals at this point.
    Here goes:
    I think the reactance for such an inductor (assuming no internal resistance) at 1000 hertz would be: 2pieFL = 973893.72 Ω
    the value of the resistor you need depends entitrely on the input voltage which you have not supplied.
    All you have to do is get the value for voltage and then use V=RI (with the condition that R is a value for impedance and is expressed in polar form)
    Then stick 3 amps in for I and solve for the required impedance. you can base your required resistor on this.
    I hope this helps and I hope to God its right.
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    That's a darn huge inductor. Is it possible that the tested value is 155mH or 155uH instead of 155H?
    <!--QuoteBegin-EE_joe
    @Oct 17 2005, 01:45 PM
    [post=11056]Quoted post[/post]​
    [/quote]
    For a 155mH or 155uH, one probably won't see any behavior with changing DC current. (Unless one has very expensive test equipment.) You will, however see change as you vary the AC frequency.
    If it truly is a 155H coil, then you will indeed be able to watch it oppose the change in DC current.
  5. JoeJester
    Apr 26, 2005
    3,394
    1,212
    You could use an Excel or any spreadsheet to see what you can expect.
    Anything past DC you can expect the voltage to decrease across the resistor and the voltage to increase across the Inductor.
    I put a 15 ohm resistor in series with the 155 H inductor. A 50 volt source gave me a little over 3 amps in the DC circuit.
    Anyways, here's a plot of the voltage across the Inductor and the Resistor from 0 to 1 Hz.
