Testing a TSOP1738
Discussion in 'General Electronics Chat' started by rvm.karthi, Feb 10, 2010.
  1. rvm.karthi
    Dec 29, 2009
    13
    Hi could any one help me to test the tsop1738 is good or not........?
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    I told you how to test the TSOP1738 in another thread or on another forum.
  3. rvm.karthi
    Dec 29, 2009
    13
    Hi guru..
    Could you share that link for testing tsop pl...
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings rvm.karthi.
    Posting your question on more than one forum is a perfectly good way to cross check suggested solutions. It also gives you a larger audience for your specific problem since others may have your same problem and can benefit from the suggestions provided.
    hgmjr
  6. rvm.karthi
    Dec 29, 2009
    13
    [​IMG]Hi
    i got this circuit n i tried but i am getting 4.9v in output without giving any ir rays... can any one help me pl....
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    If you got a circuit, post it here and we will have a look at it.
    Greetings,
    Bertus
  8. rvm.karthi
    Dec 29, 2009
    13
    i have it as a bitmap how can i post that one?
  9. rvm.karthi
    Dec 29, 2009
    13
    That circuit is simple, 100 Ohm serious with input 5vdc and 10k parallel with i/p and o/p then 4.7 microfarad with i/p and ground....
  10. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    That is said in the FAQ:
    Succes,
    Bertus
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    A bitmap uses very many digital bytes. Convert it to a PNG file type that uses few bytes and is very clear. Use Microsoft Paint program to convert it.
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    The datasheet for the TSOP1738 shows that its output goes low (with a fairly low amount of current drive) when it receives IR bursts of 38kHz. Without a modulated IR input it output is normally high like yours has.
  13. rvm.karthi
    Dec 29, 2009
    13
    Pl look at tis....
  14. dreamcatcher
    Jan 5, 2010
    27
  15. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  16. rvm.karthi
    Dec 29, 2009
    13
    But i am using the LG AC remote control only kno...... does it not gives the modulated O/P........?
