I pulled a transformer out of an radio's power supply circuit that I had. I was going to use it for protyping. How would one go about testing what it converts from and coverts to?
http://www.dropbox.com/s/o4a6zx61qemzmvx/photo mar 28, 11 35 21 am.jpg?dl=0 there you go. A photo of itIf it is mains input then apply power to the primary and measure the secondary(s) voltage(s), you could do a resistance check to find out if the secondaries are connected or have centre taps.
The physical size of the core will give a rough estimation of VA size.
Max.
The black and white are mains leads sryA photo doesn't help that much.
Where were the leads connected? Did any of them go to the mains power?
I'm talking about the actual wound copper. Inside the motor on the motor shaftWhat does that have to do with a motor armature and where/what is the Tfmr?
Max.
Thread starter | Similar threads | Forum | Replies | Date |
J | transformer testing | Test & Measurement | 8 | |
G | Flyback transformer testing and replacement | Test & Measurement | 1 | |
B | Help testing a step down transformer | Technical Repair | 6 | |
Transformer Oil Testing | Power Electronics | 1 | ||
Testing TV transformer | General Electronics Chat | 12 |
by Jake Hertz
by Aaron Carman
by Duane Benson
by Jake Hertz
