I've got an electronic distributer from a truck with a reluctor and a pick-up coil and I seem to be getting intermittent output from it. A static test gives the proper resistance, now I want to test it running.
The question is, what kind of signal does it produce and how best is it tested with the engine running? Is it a very low voltage pulsed DC? And how best to test it while the engine is running so as not to interfere with the signal/running of the engine? I plan on back probing the plug at the ECU.
I've got a Simpson 260 analog VOM (20K Ohms/V), is this sensitive enough to measure what I am guessing is a fairly small signal without interfering with it?
I also have a fairly decent DMM but I don't know if the DMM is quick enough to lock on to this kind of signal?
