Testing a motor for wi d generating potential
Discussion in 'The Projects Forum' started by iONic, Sep 3, 2008.
  1. iONic
    Thread Starter AAC Fanatic!
    Nov 16, 2007
    1,422
    68
    Does anybody know what is a good way to test a motor (in this case a treadmill motor rated at 130V, 2.5HP, 18A.
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    ???:confused: You want to use a motor to generate Wisconsin Democrats? :confused:???
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It will have to be a DC motor. If it's permanent magnet (not likely), then arranging to spin it from another motor and putting a load on it won't be too difficult.
    Fro one that size, you would need to feed a current to the armature to create a field and then measure the output under load.
