24 watts for a scooter horn? That seems like a lot, but again it might be aimed at an older, somewhat hearing impaired audience.
But yeah, a step down transformer should do the task. Radio Shack has a 12.6VCT/3A for 12 bucks... center tap to either end is 6.3VAC or close enough. Current by your spec is low but I think the spec may too high anyway. Not like it will explode for a short test.
I would never suggest you clip this to the line, try the horn, then return the unit back to the Shack. <wink> <wink>
Thanks! I found the P/N t be 273-1511-A. However, quality being what it is these days, the reviews seem to indicate a high failure rate. HMMM?24 watts for a scooter horn? That seems like a lot, but again it might be aimed at an older, somewhat hearing impaired audience.
Hi,I had a scooter like that back in the late 50's. It was made by Vespa/Piaggio, but it was marketed by Sears as a "Super Crusaire." I had a lot of fun (and a fair amount of pain) with it.
ETA: Looks like the one in your picture has inflicted its share of scrapes and
bruises.
by Jake Hertz
by Duane Benson
