Tester for PCM cables 120 ohm
Discussion in 'Wireless & RF Design' started by hanih, Feb 13, 2011.
  1. hanih
    Feb 13, 2011
    HI all,
    I have PCM cable or E1 cable
    how I can make testing for its ohm bu ahmmeter
    is there any way
    many thanks for all
    Hani
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    I can't decipher your question.
    Are you trying to find the current handling ability of a wire?
    The resistance of a wire?
  3. hanih
    Feb 13, 2011
    many thanks for your reply
    as you know E1 cable(pcm) is 120ohm and network cables is 50 to 60 ohm
    so now i don't know exactly what is meaning by this ohm? and how i can find out this ohm by ohmmeter
    thanks again
    hani
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  5. hanih
    Feb 13, 2011
    many thanks
    PCM cables are totaly different it not coaxial cable
    Hani
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Take a look at the attached PDF.
    It is a lecture note.
    Bertus
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    The "Ohm" of the cable is the characteristic impedance. The CSU/DSU and Telco Demarc handle the "Electrical termination" for you, so you only need to use cable that is within the specification.
    As you mention E1 vs. T1 or DS1, I assume you are non-US? Are you trying to use a different connector cable for the E1?
