Test Testup
Discussion in 'The Projects Forum' started by magantiamala, Jul 24, 2012.
  1. magantiamala
    May 8, 2012
    25
    Hello Everybody,
    I need a very urgent help, i have built a test setup with mosfets ,diodes resistances and too much wires connected like voltmeter etc, and now i just want to make it simple , like i want to build all this in a box like thing and placing my mosfet outside.
    When my mosfet fails, i can only remove my mosfet and replac it with new one instead of disturbing the whole circuit, could anyone please provide me some ideas for easy building.
    Thanks in Advance.
    Regards,
    Amala Maganti
  2. mcasale
    Member
    Jul 18, 2011
    210
    12
    Do you have a schematic to share?
    What are you testing?
  3. shortbus
    Sep 30, 2009
    4,095
    1,683
    Unless your "testing" the mosfet, wouldn't it be better to redesign the circuit so the mosfet doesn't fail?
    Please post your circuit and describe the "testing" your doing.
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
    So it seems like your question is how to easily replace a mosfet when it fails..
    Is the mosfet the actual "unit under test" or is it just a part of your testing devices circuit?
    If its not the UUT then I would ask "why is it failing so often that you feel the need to make it easily removable?" Why don't you fix it so it doesn't fail?
    doh shortbus beat me..
