Test points in Orcad
Discussion in 'The Projects Forum' started by HMartins, Mar 26, 2013.
  1. HMartins
    May 10, 2011
    21
    Two things (Orcad).
    1 - How can I get a no_hole 5x5mm square footprint so that I can relate it to a test point anchor?
    2 - Capture shows green circles next to each connector or test point (single pin connector) because there is no PSpice model for that. It's fare. So, the diagram looks like a fied of greens because there are many test points and connectors. Is there such a thing as a PSpice dummy model so that it could be related to test points an connectors?
    Martins
  2. kubeek
    Sep 20, 2005
    4,691
    806
    #1 is simple, you crate a footprint with a single smd pad of you desired shape, then use it as a footprint for you testpoints.
    #2 could be a bit more tricky, can't you just disable the warnings for this? You could try making a pspice model with a single net? and assign it to that schematic part.
