Dear friends,
I read some simple test in the article http://webdevelopersjournal.com/columns/greg3.html. It goes like this...
"What do you do when something goes wrong? Get out your little multimeter and test the cable. From any T-connector, you should read 27 +/- 5 ohms; from any end of the cable, remove one of the terminators, and you should read 55 +/- 10 ohms. Remove BOTH the terminators, and you should read open circuitinfinity ohms! If you get these readings, your cable is probably A-OK. If not, track it down".
I did this test with my setup. It seems ok. But I cannot find an explanation to why we should read 27 +/- 5 ohms at each T connector.
I would really appreciate any hint from any one.
Thanks in advance,
irastha
Thanks in advance,
irastha
