Test circuit for dac ic (0800)
Discussion in 'The Projects Forum' started by dandrous, Mar 2, 2015.
  1. dandrous
    Mar 2, 2015
    22
    i would like to develope a DAC 0800 ic tester..how can i test a dac ic?
  2. MrChips
    Oct 2, 2009
    12,652
    3,460
    Build an 8-bit binary synchronous counter circuit clocked by a 555 timer circuit and apply the 8 bits to the input of the DAC.
  3. dandrous
    Mar 2, 2015
    22
    how can i compare the output and input..to find error?
  4. MrChips
    Oct 2, 2009
    12,652
    3,460
    Measure the output on a digital voltmeter.
  5. dandrous
    Mar 2, 2015
    22
    sory..i just want to make it as a ic tester equipment..just like an ic tester..
  6. MrChips
    Oct 2, 2009
    12,652
    3,460
    What are you testing?
  7. dandrous
    Mar 2, 2015
    22
    how can i relate the input applied to dac and output obtained from dac...i know that for each binary input there will be different voltage levels ..so my idea is to find any deviation from the output voltage for particular input can be considered as a error
    for example
    for a good working dac when ever i apply 10000000 at input suppose there will be an output 9v
    for another ic (faulty one) if got 5v with all same parameters that is an error..
    so i want to check all the 8bit input combinations inorder to ensure all combinations are working
  8. MrChips
    Oct 2, 2009
    12,652
    3,460
    Put eight toggle switches on the digital inputs. Read the output voltage on a DVM.
  9. dandrous
    Mar 2, 2015
    22
    mrchips i already mentioned that i want to devlope it as an equipment ..it shoud be userfriendly..icluding only one "test "switch is prefered...
  10. MrChips
    Oct 2, 2009
    12,652
    3,460
    You mean to say you wish it to be an automated process. You didn't say that before.
    Output 8 bits from a computer and read the voltage using an ADC or digital voltmeter with a minimum of 12-bit resolution.
    dandrous likes this.
  11. dandrous
    Mar 2, 2015
    22
    why 12bit adc? 8bit adc is enough?
  12. MrChips
    Oct 2, 2009
    12,652
    3,460
    How are you going to measure ½-bit errors? You want the ADC to be better than the DAC by at least 2 bits.
  13. atferrari
    Jan 6, 2004
    2,672
    785
    Something I did when I started to deal with DACs was to run them driven by a counter and check the output with a scope for linearity.
    Not sure about fine details but I could see easily how it worked. More or less what you do when implementing an R2R network.
  14. dandrous
    Mar 2, 2015
    22
    how i can test linerity?
  15. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The same way you test any dataset for linearity. If the points are within some small deviation from the equation of a straight line then the dataset is linear. You test this by selecting a sample and calculating the mean deviation from the equation of the line and the variance of those deviations.
    The freeware language `R' is really helpful with this stuff.
    http://www.r-project.org/
  16. dandrous
    Mar 2, 2015
    22
    check the circuit i have drawn ..it is for testing a dac ic..the concept is that a dac ic convert digital input to analogue and this analogue is passed to the adc..and the obtained digital output is compared with the input ..when the sequence input and output is same its clocked the flipflop to count next state and so on..i wish to use johnson counter when ever there is a mismatch between input and output the counting is stopes and fail indication led is lights..when counting a set of sequence completed it is driven to a pass indication led(i forgot to add a not gate besides that led leav it)..please help me to develop the circuit..and tell me any errors in this..
  17. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The choice of an 741 in your circuit is not so good.
    It has quite some offset and noise.
    Bertus
  18. MrChips
    Oct 2, 2009
    12,652
    3,460
  19. dandrous
    Mar 2, 2015
    22
    i wil replace it with other opamps..is there any other problem>?
  20. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Why do you post such large images?
    I did reduce it to about 600 Kb, but you have put up the 2.5 Mb again.
    Not everybody is pleased with that huge image.
    Have a look here to select an opamp:
    Op Amps
    Bertus
