Terms in Algebra
Discussion in 'Math' started by Lightfire, Sep 30, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    In the other hand,
    The first one was told by somebody and the second one was written somewhere in the internet.:D
    I really got confused. By the way, somebody told me that it may do with minus. But in our notes, it's only addition.
    However, look at this 5x^{3}-3x^{2}+x+7
    Somebody asked me, how many terms are there in this expression, I said Three!:)
    But somebody corrected me that there were four.:confused:
    So, meaning separated by either an addition or subtraction not addition only?
    Thank you very much.
  2. djsfantasi
    Apr 11, 2010
    2,900
    874
    Consider this - subtraction is the addition of a negative number. So either addition or subtraction separates terms and both definitions do not conflict with each other.
    Lightfire likes this.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    You have four terms in this expression:
    1. 5x^3 - the third order term
    2. 3x^2 - the second order term
    3. x - the first order term
    4. 7 - the zero order term
    In general, I would say that a term is a "group" of numbers and variables that are "bound" to each other only by multiplication and division.
    It's no big deal, you 'll have it figured out very fast.
  4. HunterDX77M
    Sep 28, 2011
    104
    Yup, there are four terms in that. Your second quote is the correct one. If you want to think of it another way, there is no mathematical operation of subtraction. :eek:
    Its just addition of negative numbers.
    2 - 1 = 2 + (-1) = (-1) + 2
    Hope that helps! :)
