Hi everybody!
Hi everybody!Hi everybody!
I'm surprised no one has said, " if you have to ask, maybe you shouldn't be messing with it". Not knowing input from output on a neon transformer sounds like a 'Darwin award' candidate in the making.I'm surprised nobody has asked for a photo yet
Could you post an image of the NST? It will definitely help. You can usually tell the outputs from the inputs based on either the insulation thickness (if the wires are insulated), or the large bushings on the outside (if the outputs are bolts).
Shortbus, that is an excellent point.I'm surprised no one has said, " if you have to ask, maybe you shouldn't be messing with it". Not knowing input from output on a neon transformer sounds like a 'Darwin award' candidate in the making.
In some cases, yes, but when it comes to Tesla coils you really MUST know what you are doing. You may not get a second chance if you screw up once.I know high voltage Tesla coil is no joke. But I really want to build one. I mean the best way to learn something is to build it right?
The large bushings towards the top of the NST (on the sides) are the high voltage outputs. The bolt that looks like it's connected directly to the case is center ground (this is what you'll want to connect the middle prong of your safety gap to), and the connections at the bottom of the one side are the mains connections.I take lots of caution while working on this and it's why I asked here. And this is the pics of my NST:
Thanks. That's what i though too. Have a good day!In some cases, yes, but when it comes to Tesla coils you really MUST know what you are doing. You may not get a second chance if you screw up once.
Much of your learning must be by the book at first. And even after you've gained a firm understanding of the circuits, the dangers, and so on you must practice extreme caution when building. As I said before, it's always a good idea to have someone nearby who knows CPR, or even better, someone who has built a Tesla coil before AND knows CPR.Respectable contributors that actually know how to deal with those scaring transformers: how did YOU learn? Asking, watching or divine inspiration?
I would be here asking as he did.
I understand Matt; with that high voltages and lasers there is no second chance, I know.Much of your learning must be by the book at first. And even after you've gained a firm understanding of the circuits, the dangers, and so on you must practice extreme caution when building. As I said before, it's always a good idea to have someone nearby who knows CPR, or even better, someone who has built a Tesla coil before AND knows CPR.
Not at all atferrari, it was a valid questionI understand Matt; with that high voltages and lasers there is no second chance, I know.
I did not want to sound sarcastic. Sorry if it was construed as such.
by Duane Benson
by Jake Hertz
by Jake Hertz
by Duane Benson
