Tempra 24 24.0 kW tankless water heater modification
Discussion in 'The Projects Forum' started by yonkss, Oct 2, 2014.
  1. yonkss
    Oct 2, 2014
    I have a
    Stiebel Eltron
    Model # Tempra 24
    Tempra 24 24.0 kW Whole House Tankless water heater. I want to install a on delay relay from the flow switch so unit will not run for 5 or so seconds after flow is sensed. This is to alleviate the problem of a quict turn on to rinse hands and the unit starting and not actually getting hot water to the faucet. Bill way too high.
  2. Dodgydave
    Jun 22, 2012
    5,154
    772
    why don't you use the cold tap instead to rinse your hands?
    SgtWookie likes this.
  3. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Google 'time delay relay'. But I second Dodgydave's method :).
  4. tom_s
    Member
    Jun 27, 2014
    287
    342
    never liked the idea of electricity heating water. also voting for the cold water :)
  5. wmodavis
    Oct 23, 2010
    737
    150
    Dave has the optimum plan.
    Train users to use cold water tap instead of hot unless they absolutely want/need the water heated.
    I have a whole house electric water heater and think it is an efficient way to go.
    People can be trained.
    Now if you set the delay to 10 min that might help users to get the idea. Forced training.
    Dodgydave likes this.
  6. crutschow
    Mar 14, 2008
    13,501
    3,375
    Any delay on the turn-on of the water heater will just waste water when you actually want hot water.
    I vote will all the rest. Use the cold water faucet if you aren't going to wait for hot water. If necessary, to train others in the house, post a sign. ;)
