Pray for such thing not to happen Or you can use the program flash memoryHAve looked in spec, and see that 16f1509 have no EEProm, how should i then store numbers i case of powerloose. ?
Try to update MPLAB. If you are using the version that came with your PICKIT. It is to oldHi
Have recieved the part.
Now i will get started BUT i miss the possibility to chose 16F1509 in MPLAB
How should i fix that ?
Works, but now another problemTry to update MPLAB. If you are using the version that came with your PICKIT. It is to old
Ah...I missed that. It is supported by PICKIT 2 but only from the PICkit 2 Programmer Application v2.61. Just do your work in MPLAB as usual. Then program from the PICkit 2 Programmer ApplicationHave your read this?
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en027813
And the usual restart of the computer...
Have check it all. But still when loading hex it tells the warning that no config in hex.
But if i set in programmer and program chip. No work on lcd
What have you changed in the code?Have check it all. But still when loading hex it tells the warning that no config in hex.
__CONFIG (FCMEN_ON & IESO_OFF & BOREN_OFF & CP_OFF & MCLRE_OFF & PWRTE_ON & WDTE_OFF & FOSC_INTOSC);
__CONFIG (LVP_ON & LPBOR_OFF & BOREN_ON & STVREN_ON & WRT_OFF);
by Jake Hertz
by Jake Hertz
by Duane Benson
by Aaron Carman
