Temperature Switchfor fridge monitoring
Discussion in 'General Electronics Chat' started by RodneyB, Oct 14, 2015.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    647
    14
    I have a small fridge that I need to know when the temperature gets to 7 degrees. I will then connect it to a GSM module to send me a message. I was thinking of using the LM35 but got very confused at all the circuit on the internet.
    Really looking for advice and direction
  2. cmartinez
    Jan 17, 2007
    3,698
    2,773
    The challenge to your project is to keep it as simple as possible. You may start by using a digital thermometer connected to a small MCU, such as the DS1822. Frankly, I can't think of anything simpler (nor cheaper), since you'd need the MCU to interface it to the GSM module anyway.
  3. wayneh
    Sep 9, 2010
    12,379
    3,232
    I don't disagree, but the LM35 is very easy to use also. The slight challenge here is that the low temperature will produce a low output voltage, and thus you need circuitry that senses close to the negative rail, ie. a rail-to-rail op-amp or a comparator. Once you use a comparator to switch, like a thermostat, at the trigger temperature, the output is digital, 0 or 1, on or off.
    cmartinez likes this.
  4. #12
    Nov 30, 2010
    16,672
    7,314
    Here's an idea. Refrigerators are not freezers, so the spec must be in Centigrade. Use a Fahrenheit sensor to detect 44.6 F. That will get you a higher voltage for the set point.
    RodneyB and cmartinez like this.
  5. cmartinez
    Jan 17, 2007
    3,698
    2,773
    Yes, I hadn't considered an analog thermometer for this application, since I feel that the OP will probably end up having to use an MCU anyway... but maybe not. Your analog comparator idea is simpler, and does not involve programming. So now what's left to know is what kind of GSM module the OP is planning to use, and how it's supposed to be interfaced.
  6. cmartinez
    Jan 17, 2007
    3,698
    2,773
    The only sensor calibrated for Fahrenheit output I could find is the LM34. It's able to read 5°F to 300°F with a single supply. So yes, the set point would be higher than if he were to use an LM35, making the use of a comparator simpler.
    EDIT: The thing is more than $6 dlls a pop and requires a minimum quantity of 1,000 at Digikey!
  7. wayneh
    Sep 9, 2010
    12,379
    3,232
    Yeah, I wanted to use the LM34 for a project because of the higher sensitivity, but gave that up when I found how much rarer the piece is.
    But the LM35 would be fine at 7°C. That's 70mV output and the LM339 would have no problem there. 7°F is a different story. I assumed we were in °C, as #12 noted also.
  8. cmartinez
    Jan 17, 2007
    3,698
    2,773
    So did I... last time I checked, Zimbabwe used the metric system.
  9. Dodgydave
    Jun 22, 2012
    5,143
    768
  10. cmartinez
    Jan 17, 2007
    3,698
    2,773
    Well I'll be... this is the first time I've heard of that sensor, it's pretty affordable in Digikey. And it's got a very complete datasheet with example circuits and all.
    Dodgydave likes this.
  11. Dodgydave
    Jun 22, 2012
    5,143
    768
    Used it many times, made a fridge freezer thermostat, indoor outdoor thermometer,...blah blah....
  12. cmartinez
    Jan 17, 2007
    3,698
    2,773
    Did you couple it to an ADC? And if so, what chip did you use?
  13. marcf
    Member
    Dec 29, 2014
    149
    20
    DS1821 is a stand-alone 1 wire programmable thermostat. Set it and forget it.
  14. cmartinez
    Jan 17, 2007
    3,698
    2,773
    Yes, it's a viable choice, but it requires programming to set it, and I'm not sure if the OP has the skills to do that.
    Also, I couldn't find any available in Newark, Mouser nor Digikey.
  15. crutschow
    Mar 14, 2008
    13,481
    3,368
    The main question seems to be, what type of GSM module the OP will use?
  16. cmartinez
    Jan 17, 2007
    3,698
    2,773
    Exactly my point in post #5
  17. RodneyB
    Apr 28, 2012
    647
    14
    Wow thank you for all the information.
    The GSM module is a Wilarm- Micro
  18. cmartinez
    Jan 17, 2007
    3,698
    2,773
    A datasheet would come in handy
  19. RodneyB
    Apr 28, 2012
    647
    14
    Oops sorry here is the data sheet
  20. cmartinez
    Jan 17, 2007
    3,698
    2,773
