temperature sensor
Discussion in 'The Projects Forum' started by braddock, May 28, 2009.
  1. braddock
    May 28, 2009
    please help me ! i need temperature sensor circuit with seven segment display that range 0-500*C.
    i appreciated if member give the solution
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    You can buy them premade from companies like Omega much easier than making one. Is there a requirement it has to be made by you?
  4. braddock
    May 28, 2009
  5. Chris15
    Apr 15, 2009
    252
    Hey Braddock
    Go into google and type in how to make a computer thermometer, and there is a great plan that tells you the temperature of your computer and the outside temperature on the bottom of your taskbar
    Good luck Chris15
  6. Bernard
    Aug 7, 2008
    4,240
    414
    Alnor thermocouple probes type J, F temp. range -100 to 1200 @ about US $8. Cat #s, 9230,9280.9290,9440,& 9710. www.sciplus.com
    And I was just looking for lables & got curious.
  7. Bernard
    Aug 7, 2008
    4,240
    414
    Type ' J " output fairly constant at 54.5 μV / deg C.
  8. Bernard
    Aug 7, 2008
    4,240
    414
