Temperature sensor
Discussion in 'Programmer's Corner' started by RRITESH KAKKAR, Mar 21, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    Hello guys,
    I have LM35DZ it has 3 pin working at 5V of micro controller supply inbuilt ADC of 8 bits.
    so, I want to convert 8 bits maximum value 0-255 5v, 10mV mean 1*C
    please tell algorithm to convert it in 0 to 99*C
    thanks
  2. nerdegutta
    Dec 15, 2009
    2,565
    806
    Hi, I found this on a website, while I was searching for answers:
    I found it here.
  3. GopherT
    Nov 23, 2012
    6,309
    4,029
    Option 1
    Set the ADC reference voltage to .99 volts. Then you get a full scale from 0 to 0.99 volts = 0 to 255 ADC value.
    This leaves messy math to do in the Microcontroller to convert ADC value to degrees.
    Option 2
    Set reference ADC voltage to 2.55 volts
    Your ADC value will be 0 to 255 (1 tick per 10 mV) which corresponds to 1 tick per degree C
    Directly send your ADC value to your display. It is not a full 8-bit accuracy but neither is your 2-digit display. I assume 2 digit display because you said 0-99C instead of 0-99.9C.
    Cheers.
    RRITESH KAKKAR and cmartinez like this.
  4. John P
    Oct 14, 2008
    1,638
    225
    Run the processor on 5.12 Volts, with the power supply used as the reference. Probably the A/D actually has 10 bits of resolution; read it in "right justified" mode and ignore the top 2 bits which will be in another register. You've then got 256 levels of resolution over an input range of 1.28V, which equates to .005V per step. To get 100 levels over a 1V range, all you have to do is divide by 2.
    Alternatively, if you don't really need it to be very accurate, just use a 5V supply. It'll only be off by a couple of percent at the high end, and proportionally less at the low end.
    RRITESH KAKKAR likes this.
  5. shteii01
    Feb 19, 2010
    3,500
    511
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    There is ds18b20 which work in serial data is that fine? than LM35?
  7. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    The LM35 will require more ADC bits to capture solution is tio have less price micro with DS18b20, is that fine with PIC16F72?
  8. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Anyway, I have PIC16f887 which has more than 8 Bits ADC so, could i use it to get all range of temp -40 to 155*C and i listen that hot iron for solder run at 350*C which sensor is taht which can indicated large *C?
  9. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have more question, how to communicate with DS18B20? what does 1 wire mean?
  10. DumboFixer
    Feb 10, 2009
    219
    34
  11. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Which communication to use?
    How to send read data some example i use serial to parallel shift registers i can do that!
  12. DumboFixer
    Feb 10, 2009
    219
    34
    1-Wire communication has its own protocol so you will need to use that if you are going to use the DS18B20 temperature sensor.
    Did you look at the bottom of the page I gave you the link to ? There are several links to external pages that will provide more info or do you just want us to provide you with the solution ?
  13. shteii01
    Feb 19, 2010
    3,500
    511
    Why are you buying stuff when you have no clue how it works?
  14. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I am learning it, can we do this with pic micro?
  15. DumboFixer
    Feb 10, 2009
    219
    34
    Yes, one of my projects uses the same temperature sensor and a Pic Micro
  16. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    so, if you dont mind can you teach me?
  17. jacklai
    Mar 26, 2015
    7
    I'm working with DS18B20 & also have the same confuse...
