Temperature sensor with LCD
Discussion in 'The Projects Forum' started by Elvi Dalla Marta, Jun 2, 2015.
  1. Elvi Dalla Marta
    Jun 2, 2015
    9
  2. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Do you know how to write text to the LCD?
    Elvi Dalla Marta likes this.
  3. Elvi Dalla Marta
    Jun 2, 2015
    9
    Yes, there is a function... but i don't know how to write the adc value from RA0.
    Can you help me? Thx :D
  4. shteii01
    Feb 19, 2010
    3,504
    512
  5. Elvi Dalla Marta
    Jun 2, 2015
    9
    Can somone write the code to convert the voltalge in RA0 to a temperature to display in lcd? 0V=-20°C 5V=50°C
    Thanks so much
  6. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    If you look at the 18F sample files that are supplied with the Picdem-Demo boards, ver 1 and 2 you will find routines for all the components on the board, analogue, LCD, math, etc available on the Pic site.
    They take the module inputs from different devices on board and display on the LCD.
    One is a thermal sensor.
    The earlier version is in Assy, the ver2 is in C and Assy.
    Max.
  7. Elvi Dalla Marta
    Jun 2, 2015
    9
    Another question, for have an output range of 0-5V, someone can explain me how to createa a conditionation circuit ? Using 12 V and lm324
  8. shteii01
    Feb 19, 2010
    3,504
    512
    Why do you need conditioning circuit?
  9. shteii01
    Feb 19, 2010
    3,504
    512
  10. korchoi
    Member
    Jun 5, 2015
    59
    6
    basically you are making a 3-step thermometer.
    step 1: convert temperature to voltage.
    step 2:Convert the voltage level representing temperature into a digital value.This is done through the use of the built in ADC.
    step 3:Output an image that differs depending on the value of that digital variable.
    How to do step 2? read the microcontroller's datasheet on its built in ADC and how to use it.
    How to do step 3? Well, it's up to you. There are so many ways to do it because this is the software side.
    But i will show you a string you can pull: display images according to the value obtained eg. if 0v = -20ºC, display minus 20 on lcd.
    summary of tasks:
    -set up ADC module.
    -convert voltage to digital value.
    -drive lcd display.
    -associate lcd's state to digital value's state.In other words, the Digital representation of the temperature will indirectly control the LCD.
  11. Dodgydave
    Jun 22, 2012
    5,154
    772
    I have sent you an asm file that i used to make a fridge freezer using a TMP36 sensor,.
  12. Elvi Dalla Marta
    Jun 2, 2015
    9
    Thanks for the support, now i print the temperature in the lcd, but i have a little problem: What should i do to print the degrees simbol "°" on lcd??
  13. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    You will find the codes here.
    mil.ufl.edu/4744/docs/LCD_Notes_4-bit.pdf
    Max.
  14. Elvi Dalla Marta
    Jun 2, 2015
    9
    I write printf(%c,223) Now it's work
