temperature sensing and fuel measurement using pic 16f873 coding
Discussion in 'Embedded Systems and Microcontrollers' started by shilpa, Mar 22, 2007.
  1. shilpa
    Mar 22, 2007
    can u please help me with coding for pic 16f873 for temperaure sensing and fuel level measurement of an aero engine....
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    You will need to give more information. Please read this (particularly section 3) and provide more information so that others can be of help.
    Dave
  3. kender
    Jan 17, 2007
    263
    Temperature measurement with PIC is easy, but there are dozens of temperature sensors and the codes for them are different. What kind of temperature sensor(s) you are using (or going to use)? Give us sensor types or part numbers or - best of all - schematic for your circuit.
    Along the same lines, the code for different C compilers would be different. What compiler do you have?
    This is a much tougher problem, because the attitude of the aircraft is changing, and the level (assuming for now that it's horizontal) will be changing with respect to the tank onto which the sensor is mounted. The type and purpose of the aircraft plays a big role here, because the dynamics of Boeing 747, Mig-29, Cessna 150 and RC model airplane differ a lot. Please shed some light on this. This is a neat problem to solve.
