temperature regulator cct
Discussion in 'The Projects Forum' started by cuteram, Jun 20, 2008.
  1. cuteram
    Jun 20, 2008
    :):):)hallooooo all.please help with acircuit for teperature regulature using thermistor.temperature range 37+or _ 5degrees.currently ihave one with temperature range -20 to+50
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Why do you need the additional circuit? You state the one you have is good to +50, which is well beyond the 37 deg. you say you want to regulate.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Beenthere,
    I believe the O.P. wants a circuit that will maintain the temperature of the thermistor to within 5°C of 37°C; the circuit version he has now simply reads the temperature over the -20°C to +50°C.
    That is, if I'm interpreting his request properly - but we need verification from the original poster if that interpretation is correct.
    If that is in fact what they want, here's a link to a circuit that should do the trick:
    http://www.solorb.com/elect/constemp/index.html
