Temperature regulator +40C +60C circuit for heating element
Discussion in 'General Electronics Chat' started by alan1975, Feb 18, 2012.
  1. alan1975
    Jan 1, 2012
    42
    I come up with problem, and i'm looking up for solution.
    I got basic idea, what i want to do, but problem is with calculations.
    I have heating element, i would like to turn it on / of on certain temperature.
    I would like have range between 40 - 60 Celsius, made by few presets.
    For example
    - 40C
    - 45C
    - 50C
    - 55C
    - 60C
    I will get to that later, because idea may change during project.
    What's my idea ?
    I would like use thermistor NTC 100Ω model B57164K0101J parameters
    100Ω25*C +- 5% R=5mm
    K(B25/100)=3200 ±5%
    Idea is:
    Use 3.3V voltage source.
    Use that voltage source on voltage divider made by 100Ohm termistor AND 100 ohm resistor.
    Then use second voltage divider made by 200Ohm variable resistor.
    That 2 input, connect to LM324 OpAmp
    As fare as i remember, NTC lose resistance when temperature RISE.
    When resistance will goes down, voltage divider will go up.
    Than OpAmp Comparator will send at output signal.
    And i can plug there mosfeet or something else, like relay.
    I know i can get pre set temperatures by measuring resistance of variable resistor, measuring temp, and replace them by resistor.
    But... i'm looking for something else!
    How can i count it...
    I gues it will be better to count that on paper.
    On thermistor say
    K(B25/100)=3200 ±5%
    100Ohm in 25*C
    How calculate resistance in for example 40*C ?
    I know it's non linear.
    There are special calculator to do this ?
    Is my thinking is correct ?
  2. evilclem
    Member
    Dec 20, 2011
    118
    16
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Have you looked at the LM35 IC. For your temperature range I would recommend this instead of using a thermistor.
  4. alan1975
    Jan 1, 2012
    42
    Thank You, that's look userfull.
    From myself i would like to share this page
    http://www.giangrandi.ch/electronics/ntc/ntc.shtml
    At the bottom is calculator. You can Put there values from datasheet, and it will calculate resistance at any temperatures. I'm not sure is this reading are correct, but i hope so!.
    That's IC LM35 looks brilliant!.
    Could i conntect output directly to input of LM324 ?
    If i understand correctly, i can hook it up with +4V.
    It should add 10mV / 1C to output.
    So at 40*C i should get 400mV ?
    Is this correct ?
    What if i would like measure in 2 points ?
    Actually not measure, but detect "overheat".
    Could i connect them together in parallel and put in 2 different points ?
  5. luvv
    Member
    May 26, 2011
    186
    31
    I've done a few of the lm324 fan controllers,i always just used trim pots instead of fixed resistance.
    10k pot,10k thermistor and a handy dandy IR thermometer to set the temps to my liking.
    Word of warning w/ this setup, zero hysteresis it will kick off and on constantly as temps fluctuate.
    Another warning op amps don't like when you accidentally hook the power up reversed polarity.
    They go pop w/ no warning :D
    -luvv-
  6. alan1975
    Jan 1, 2012
    42
    That's great answer!
    I will do this way.
    I love this!
    Right now i use bimetal thermostat and that's cause problem. When it turn off, i have wait to much time until it cool down.
    That's main reason why i change to more electronic design than mechanical...
    Few years ago, i make capacitor explode ( i take from wrong box, and don't look at voltage).
    Now i always wear glasses when i'm playing with electronic, soldering iron etc. and i always recommend this. Safety first!
    Regards
  7. t06afre
    May 11, 2009
    5,939
    1,222
    40*10e-3 is 0.4 so you are indead correct. And yes you can hook it up to 4 (up to 30 volt should also be OK) Here is the applicayion note for LM35 http://www.ti.com/lit/an/snoa748b/snoa748b.pdf Your application will easy to do with a micro controller with AD converter. But it is no problem doing it in an analog way. For your two point measurement use perhaps two analog comparators.
    For your application what will be your supply voltage?
